  • Enable RIP globally.
  • Configure a route policy.
Configure a redistribute entry to announce routes of a certain source protocol type into the RIPng domain, for example, static, RIP, or direct. Use a route policy to control the redistribution of routes.
  1. In the navigation pane, expand Configuration > IPv6.
  2. Select IPv6 RIPng.
  3. Select the Redistribute tab.
  4. Double-click the value in the Enable column that corresponds with the source protocol type you want to enable or disable.
  5. Select enable or disable.
  6. Select Apply.
Redistribute Field Descriptions
Use the data in the following table to use the Redistribute tab.
Name
Description
DstVrfiId
Specifies the destination VRF ID used in the redistribution.
Protocol
Specifies the dynamic routing protocol that receives the external routing information.
SrcVrfId
Specifies the source VRF ID used in the redistribution.
RouteSource
Specifies the route source protocol for the redistribution entry.
Enable
Enables (or disables) a RIPng redistribute entry for a specified source type.
